Oil drip from Under the Radiator???
12K views 14 replies 7 participants last post by  MattInTheHat
#1 ·
Hello everyone. I'm new here and Hopeful I can get some good Advice... I have a 2008 Dodge grand caravan sxt 4.0L . I started noticing a Very small drip on the garage floor, But wasn't constant. It is coming from right under the radiator on the passenger side. and it only drips when the Van is running and Hot. does anyone have any suggestions as to what it could be or how to check? I really appreciate any Info! thanks, Dave
#4 ·
Lower part of the radiator is your transmission cooler... Does the oil appear to be dark red and smell of ATF? It is likely leaking at the cooler line's crimped aluminum clamp on rubber hose section.
https://www.moparpartsoverstock.com...ock.com/images/uploads/SimplePart - Chrysler/fullsize/a_20151001_1101148325.png
No, the transmission cooling lines are on the lower part of the AC condenser.
Check the transmission lines at the lower part of the AC condenser, it just may need to be tightened.
#7 ·
Hi Dave,
Sorry to hear about this! If you decide to visit your local dealership I'd be happy to follow up with them if needed. Just PM our page and let me know.
Andrea
Chrysler Social Care Specialist
#10 ·
Since you are working with AC pressurized system, your best bet is to take it to an AC shop so they can properly remove pressurized refrigerant and then recharge the system. Refrigerant should not be released to the atmosphere, federal laws penalizes licensed person who knowingly discharge refrigerants to the atmosphere, of course, if you don't have a license, you will not be penalized, but still, do the right thing if possible.
#12 · (Edited)
So tranny fluid now runs through the A/C condenser? Did that start with the 08 5th gens?
I take it a tranny fluid leaking from the condensor wouldn't necessarily mean he also has a A/C refrigerant leak rendering his A/C weak or dead.
Yes, started on 5 Gen. but not sure if started on 08. Mine is a 2012 and is built that way.
No, it would not affect the AC system at all, but if you have a transmission fluid leak, then the whole AC condenser must be replaced.
#13 ·
Would it be possible to just add a transmission oil cooler in front of the condenser and detach the trans lines from the condenser and attach them to the new cooler? Just blowing out the old fluid from the condenser? I really don't wanna mess with the a/c seeing it's working fine. Thoughts?
#15 ·
Just found this thread, is anyone still getting notifications on this? I have an 08’ T&C 4.0 Limited.....and whoah am I (do still) have the exact same issue/problem. But my A/C line blew first, followed by leaking red fluid (ATF) and now a Tranny that won’t shift out of 1st gear, thinkin I cooked it. Let me get this straight, Is the A/C condenser (if damaged) part of or can affect the tranny cooler? Effectively a possible culprit or cause for transmission issues?
